- Automatic grinding wheel balancing ensures the grinding wheel is balanced throughout the grinding process. If the machine’s wheel isn’t balanced, it can cause a vibration, which causes major disruption. That disruption ruins that quality surface finish you’re aiming for with the grinding process.
Using these technologies will help significantly with efficiency, to provide you with the maximum productivity that your grinder is capable of. Not to mention, when you properly use these controls, you lessen the need for highly skilled labor, something grinding machines of the past required. If you need help getting the most out of your controls, contact your local distributor for a showing.
Contact Your Local Okuma Distributor for a Quote
