“We’ve always done it that way.” Don't let this be your mantra for machining methods. Manufacturing companies must keep their methods current to stay competitive, and that means learning the latest skills and processes. You need to produce parts more efficiently and accurately and that involves learning.
Education is key to staying competitive, and the Kennametal Knowledge Center knows this. They teach the latest machining practices and focus on the process, regardless of the tooling brand you use. Because it doesn't matter what brand of tooling you use if you aren't machining by the best method.
Metalcutting Application Course: June 5-8 , 2017
There’s a Metalcutting Application Course coming up June 5-8, 2017 in Latrobe PA. This course is designed to provide a broad base of knowledge for the selection and use of metalcutting tools. The four-day seminar is intended to provide state-of-the-art information to mechanical engineers, manufacturing engineers, industrial engineers, tool engineers, process engineers, shop supervisors and technical specialists in machining.
Learn more about the Metalcutting Application Course.
