- TAS-S (Thermo Active Stabilizer – Spindle) CNC Control Technology:
Spindle temperature sensors are located top and bottom to provide real-time feedback to the OSP control. Spindle rotation, spindle speed changes, and spindle stoppage are all monitored. Based on this feedback, the CNC control automatically compensates for thermal deformation – without operator intervention.
- TAS-C (Thermo Active Stabilizer – Casting) CNC Control Technology:
Casting temperature sensors are incorporated using the exact number needed for the particular CNC machine. These sensors deliver real-time temperature feedback data from the casting to the control. Based on this feedback, the CNC control predicts and automatically compensates for thermal deformation in machine construction when both casting and ambient temperatures change. All without operator intervention.
OKUMA’S MECHATRONICS APPROACH: THE FOUNDATION FOR THERMO-FRIENDLY CONCEPT
The foundation for Thermo-Friendly Concept lies in Okuma’s longstanding commitment to the mechatronics approach to CNC machine design. This full-circle methodology involves a blend of mechanical engineering and electronic control development, thus assuring optimum communication between the machine and the CNC control. This commitment to mechatronics led to the establishment of a thermal testing room in 1987, and accumulation of thermal data for over 30 years. Only actual CNC machine test data has been used. Through this time over 200 volumes of data have been analyzed to enable the creation of thermal maps. The data and mapping provide the framework for developing the CNC machine casting design, the spindle designs, and the TAS compensation software utilized in the Okuma CNC control (OSP).
MAXIMIZING PROFITABILITY
Thermo-Friendly Concept delivers enhanced machine tool cutting performance, increased machine accuracy, and reduction in costs. The result is maximized profitability for manufacturers.
For more information about Thermo-Friendly Concept and the products on which it is available, check with your local Okuma Distributor, or contact us.
